Perl Fax – Retrieve Outbound Fax Image with GetFaxImage
Download the Perl fax code samples.
The GetFaxImage method, demonstrated in the Perl fax script below, retrieves the image of an outbound (previously-submitted) fax with Perl.
The following Perl fax example retrieves the image of an outbound fax:
#/**************** Settings begin **************/
my $username = ''; # Enter your Interfax username here
my $password = ''; # Enter your Interfax password here
my $transactionID = "";
my $NS = 'http://www.interfax.cc';
#/**************** Settings end ****************/
my $client = SOAP::Lite
->uri($NS)
->on_action( sub { join '/', $NS, $_[1] } )
->proxy('https://ws.interfax.net/dfs.asmx?WSDL');
my $result = $client
->call(SOAP::Data->name('GetFaxImage')->attr({xmlns => $NS}) =>
SOAP::Data->name('Username')->value($username)->type(''),
SOAP::Data->name('Password')->value($password)->type(''),
SOAP::Data->name('TransactionID')->value($transactionID)->type('')
if ( $result->fault ) {
print $result->faultstring . "\n";
} else {
if( $result->valueof('//GetFaxImageResult') == 0 ) {
# Write the received image to a tif file with the same name as the transaction ID
open (FILE, ">>$transactionID.tif");
print FILE decode_base64($result->valueof('//GetFaxImageResponse/Image'));
close (FILE);
print "Success" . "\n";
} else {
print "Error, return code=" . $result->valueof('//GetFaxImageResult') . "\n";
