Retrieve information about a batch’s individual transactions.
GET /outbound/batches/{id}/children[?limit={number}&offset={number}]
Arguments
| Name (bold) if mandatory | Type | Comments | Default |
| id | Number | The ID of the batch for which to retrieve data. | None, mandatory. |
| limit | Number | How many transactions to return. | 25 |
| offset | Number | Skip this many transactions in the list. | 0 |
Response
If successful, an array of outbound fax structures, of detail level “summary” from the following list.
| Property | Description | Detail Level |
| result | summary | full |
| id | A unique identifier for the fax. | ✔ | ✔ | ✔ |
| uri | A unique resource locator for the fax. | ✔ | ✔ | ✔ |
| status | Fax status. Generally, 0= OK; less than 0 = in process; greater than 0 = Error (See Interfax Status Codes) | ✔ | ✔ | ✔ |
| userid | The submitting user. |  | ✔ | ✔ |
| pagesSent | Number of successfully sent pages. |  | ✔ | ✔ |
| completionTime | End time of last of all transmission attempts. |  | ✔ | ✔ |
| remoteCSID | Receiving party fax ID (up to 20 characters). |  | ✔ | ✔ |
| duration | Transmission time in seconds. |  | ✔ | ✔ |
| priority | For internal use. |  | ✔ | ✔ |
| units | Decimal number of units to be billed (pages or tenths of minutes) |  | ✔ | ✔ |
| costPerUnit | Monetary units, in account currency. Multiply this by ‘Units’ to get tde actual cost of the fax. |  | ✔ | ✔ |
| attemptsMade | Retry attempts actually performed. |  | ✔ | ✔ |
| pageSize | A4,Letter,Legal, orB4 |  |  | ✔ |
| pageOrientation | PortraitorLandscape |  |  | ✔ |
| PageResolution | StandardorFine |  |  | ✔ |
| rendering | Standard(optimized for black & white) orFine(optimized for grayscale) |  |  | ✔ |
| pageHeader | The fax header text inserted at the top of the page. |  |  | ✔ |
| submitTime | Time when the transaction was originally submitted. Always returned in GMT.
| subject | A name or other optional identifier. |  |  | ✔ |
| destinationFax | The resolved fax number to which the fax was sent. |  |  | ✔ |
| replyEmail | E-mail address for confirmation message. |  |  | ✔ |
| pagesSubmitted | Total number of pages submitted. |  |  | ✔ |
| senderCSID | Sender’s fax ID. |  |  | ✔ |
| attemptsToPerform | Maximum number of transmission attempts requested in case of fax transmission failure. |  |  | ✔ |
| contact | The text which was inserted into the Contacts property upon submission of the fax (available in select submission methods only). |  |  | ✔ |
Sample Call
Get batch child faxes. Return up to 10 results and skip 5 transactions each time
